There's a setting in Steam to show you as online or offline. I forget exactly where it's located.
https://linustechtips.com/topic/880895-wifi-issues/#findComment-10889808
6 minutes ago, Lowspecgamer said:
Idk this is impossible
Here I just copy and pasted the website in the spoiler.
Required Ports for Steam
Which ports do I need to open on my router or firewall for Steam?
To log into Steam and download content:
  • HTTP (TCP port 80) and HTTPS (443)
  • UDP 27015 through 27030
  • TCP 27015 through 27030
Steam Client
  • UDP 27000 to 27015 inclusive (Game client traffic)
  • UDP 27015 to 27030 inclusive (Typically Matchmaking and HLTV)
  • UDP 27031 and 27036 (incoming, for In-Home Streaming)
  • TCP 27036 and 27037 (incoming, for In-Home Streaming)
  • UDP 4380
Dedicated or Listen Servers
  • TCP 27015 (SRCDS Rcon port)
Steamworks P2P Networking and Steam Voice Chat
  • UDP 3478 (Outbound)
  • UDP 4379 (Outbound)
  • UDP 4380 (Outbound)
Note:
Many university networks and proxies block required ports for Steam operation - please consult your network administrator to ensure the required ports are open if you are using a university network or a proxy. Ports required for Steam can not be re-mapped to HTTP or reconfigured to a custom port range.
Advanced
For generic Steam HTTP/HTTPS requests, your proxy should allow the following domains:
  • steampowered.com
  • steamcommunity.com
  • steamgames.com
  • steamusercontent.com
  • steamcontent.com
  • steamstatic.com
  • akamaihd.net
Most of the non-web traffic is usually UDP but can be TCP as well. For that, the IPs will all be from the Valve network (AS32590), and a list of those IP blocks can be found here:
3
https://linustechtips.com/topic/880895-wifi-issues/#findComment-10889937
Just now, Blebekblebek said:
Your dad seems blocking all connection to steam.
Ask him to unblock steam.
well he manages it but he doesn't know that much about actually changing things if I were to ask him he would not know what to do it seems im coming to a dead end and Im not going to be able to game online
https://linustechtips.com/topic/880895-wifi-issues/#findComment-10890030
