I don't know if motherboard that I'm planing to buy supports virtualization. I I'm planing to buy Asus B350-Plus paired with Amd ryzen 5 1600. I'm planing to use it as Nas (used from time to time) and gaming (gtx 1060 16gb of ram) rig. I'm planing to have 4 1TB HDD and 1 120GB samung 850 evo. Four HDDs will be in RAID 5 array. How powerfull psu do i need and how much ram do i need to give to Nas and how much to Windows.
Thanks for all your help!
Jack
https://linustechtips.com/topic/880789-guys-help-me/
450w PSU is enough, though 550w is recommended (can go 650 if it's not much more expensive)
Desktop benching:
https://linustechtips.com/topic/880789-guys-help-me/#findComment-10888767
Jack
If the NAS side is only serving files, you can get away with 1 or 2GB of RAM.
https://linustechtips.com/topic/880789-guys-help-me/#findComment-10888776
