I did linus tech tips computer desk build. My computer is a i7700k 16drr4 1080 ti.
water cooled parts
2 ekwb 360 rads
2 ekwb d5 pumps
2 EKWB EK-RES X3 400 Reservoir
 now the question I'm totally new to the pc water loop this is my first.
Do I need to run both pumps in this loop or is 1 find? I don't plan of adding anything else to loop.
what power supply watts should I run on my setup?
I need help with fittings I know I need g 1/4 thread but I have no idea on this or tubing. I'll be trying hard tubing and what kind of tubing sizes. I'm open to what sizes you all think I should use.
https://linustechtips.com/topic/880695-need-a-little-help-with-custom-loop/
2 pumps are generally run when you want redundancy, that way if one fails you aren't stuck waiting for a replacement before you can use your system again. Should be fine with one though
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
One pump will be fine. I’d run two just because of space and looks.
Id do a quality 850 watt.
Size of tube will be on you. Depends on how tight you need some bends which shouldn’t b much. 13mm od should be good.
Plenty of brands for fitting and and tubing.
Id and od need to match on both. So best to stick to matching brands.
Check out performance PCs and looks around their site.
Just now, Jertt said:
fittings are the same right for soft or hard tubing?
No, though primochill sells soft tubing adapters for their hardline fittings
Want to custom loop?  Ask me more if you are curious
Ok I'm lost. Damascus could you point in the right fittings/brand hard tubing and fittings I want either white prolly or black fittings for hard tubing theres just to many sizes lol
If youu stick with just primochills website they only sell one size and have all sorts of colors
https://www.primochill.com/collections/revolver-sx-compression/products/primochill-1-2in-rigid-revolversx-series-fitting-sky-white-12-pack
thanks a lot man do primochills sell hard tubing also
Yup, revolver fittings + the in house hard tube will work like a charm
ok hey man thanks a lot is there a bending tool kit you prefer. I have bent many copper tubing and electric conduit before so tubing should be to bad.
The primochill kit is aok, check out jays2cents vid on bending petg.
