So I have a PC Specs are:
Ryzen 1600 (Stock Cooler No Overclock)
MSI RX 580 8G
16 GB DDR4
1 Gigabit wifi access
BUT I also have a Macbook Air 2014
The problem here is, I can easily stream games like fortnite from my PC to my Macbook and play without any problems, but I also want to play Modded Minecraft. And here is the problem.
I cannot even launch Minecraft with those mods that I like to play with on my Macbook. But my pc crushes the framerates and is very smooth. Now I want to play on Macbook and the only way is to stream from my pc (atleast for me)
So, I tried Chrome Remote Desktop. Every control is fine EXCEPT the fact that I cannot use a mouse or trackpad to look around. It would either look straight up or straight down. Then I tried Team Viewer. The same problem but also with terrible quality compared to chrome remote desktop.
So, I want something that will let me control Minecraft while streaming it from my pc to my macbook without any controlling issues. (I can easily play fortnite and it works normally.)
Thanks to anyone who replies and helps!
https://linustechtips.com/topic/880438-i-need-help/
15 minutes ago, jblflip5 said:
Just dual boot windows and use steam inhome streaming?
https://linustechtips.com/topic/880438-i-need-help/#findComment-10885390
