triple moniter stand
Brett_UK
quick question, will a triple monitor stand that is made to hold three 27 inch displays hold one 34 inch ultra wide and two 24 inch displays ?
weight is not the issue its will the arms go wide enough, 15kg per arm and there only like 6kg for the 24's
If it says it can it can. If not it can’t. Pretty simple. They can’t test for every monitor so no way to be sure.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
i ask as they only say they fit triple 27's, so my question is are triple 27's the same width as 1 34 inch ultrawide and 2 24 inch monitors
Would still be different. As screen size has nothing to do with the overall width.
The stand curved or flat? You could get some other 27” monitor dimensions and compare that to your current monitors and see where you end up.
yh i wiil do that i think, the stand has the arms that you can move to adjust it
