About 2 days ago I cleaned deeply cleaned my computer. Like I took everything out down to the motherboard out of the case. yesterday and today I have noticed I can barely play a 720p youtube video, cant play GTA V anymore (used to get like 40 to 50 fps now only 15 to 37).  And on Friday I was playing G-mod with a friend and recording with obs, Just fine. Now I get like 19 fps when trying to do that. please help thanks. and ps I have reinstalled the Nvidia drivers and it didn't work.
https://linustechtips.com/topic/879860-help-with-loss-computer-performance/
Did you unmount the CPU cooler? If so could it be that you haven't seating it well enough and is causes it to throttle heavily. Even if you didn't I could still see the cooler needing to be re-seating with new thermal paste.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
Okay i will try this i have a little thermal paste left over  thanks
Check the temps, both graphics card and CPU
Desktop benching:
Make sure you have enough, or you will just have the same problem.
Yeah thanks
No worries.
