Hello everybody!
I would like your assistance, i just purchased two coolermaster masterfan 140 pro rgb to use with my gigabyte z370 ultra gaming. The fans have a four pin rgb cable and gigabyte has a five pin rgbw header which the manual claims to be compatible with each other. My problem is that when i try to connect them, i cannon push the pins to the corresponding fan rgb cable ports, as if the pins ports are two small (?)!!
I'm a missing something? I did not try to push them hard in fear that the might break etc. Do i have to use some kind of adapter or extension cable?
Thank you in advance!
https://linustechtips.com/topic/879149-rgb-fan-cable-problem/
Shift the header around until the pins alight with it. It's not designed well to guide the pins in.
https://linustechtips.com/topic/879149-rgb-fan-cable-problem/#findComment-10875548
