I just tried overclocking my Ryzen 3 1200 CPU to 3.7ghz at a voltage of 1.25. I ran Aida and it was saying my CPU was running at 1500mhz or 1.5ghz with an average of 36 degrees Celcius. I tried lowering the clock speeds back to the normal 3.1ghz but it kept saying 1.5ghz. I just shut down my PC so I can let it cool off. Someone help me please. Thanks.
https://linustechtips.com/topic/879110-ryzen-3-1200-overclock-problems/
Turn off Cool N Quiet, You can also go up to 1.35V if needed
Just now, Valked_ said:
It didn't work. I just restart my PC to see if that helps.
Quote them
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
11 minutes ago, Valked_ said:
It didn't work. I restarted my PC and still nothing.
Then possibly update to the latest BIOS, or start with a lower frequency
