So i installed that new windows 10 Update for the features (Feature update to Windows 10, version 1709) and for some reason now when i start up my computer everything is fine for a few seconds and then it all goes darker like all the blacks and colors get blacker.
This issue is fixed by me uninstalling and reinstalling my graphics driver although whenever i restart or shut down then start up my computer again it just happens over and over, i was wondering if anyone has the same problem or a fix for this its really confusing me. Any help would be much apprenticed.
Thanks in advance.
https://linustechtips.com/topic/879033-display-driver-problem/
2 minutes ago, xHaggis | Csoffer.me said:
This then stops me from opening up games and screws the resolution of the computer.
After the uninstall of the drivers and re-install? Or you have tried this already and ran into the issue of not being able to open games after doing so?
https://linustechtips.com/topic/879033-display-driver-problem/#findComment-10872663
That is how i fix the issue is by uninstalling and reinstalling my drivers although not restarting after i do so, but whenever i restart it causes the same issue.
https://linustechtips.com/topic/879033-display-driver-problem/#findComment-10872675
I am guessing you tried doing the same for your monitors? I ran into an issue where my monitors were in some weird color scheme after updating my driver. I had to uninstall drivers for both GPU and monitors. I think the reinstall of the monitor drivers did the trick for me. I would try unplugging the display cables and plugging them back in and see if that does anything.
https://linustechtips.com/topic/879033-display-driver-problem/#findComment-10872699
41 minutes ago, xHaggis | Csoffer.me said:
Tried this just now and still the same result. To me it seems like a feature f Windows 10 because it doesn't start instantly, it waits a second and then its like it loads up then goes dark.
I know this is not the actual 1709 update. Give this a shot.
https://forums.geforce.com/default/topic/1003026/geforce-drivers/psa-windows-1703-creators-update-breaks-colour-profiles-with-nvidia-gpus-icc-and-nvidia-/
It worked for me to disable the following option:
Home -> Gaming -> Game Bar -> "Show Game Bar when I play full screen games Microsoft has verified"
https://linustechtips.com/topic/879033-display-driver-problem/#findComment-10872922
2 minutes ago, Sergio45 said:
Try the following. Seems that the fall update is the caused.
Where is that option? Like where do i Find the "Home" setting?
https://linustechtips.com/topic/879033-display-driver-problem/#findComment-10872932
On 12/30/2017 at 10:54 AM, xHaggis | Csoffer.me said:
Sadly last night i turned off my computer and when i started it up in the morning again it was the same issue. I really have no idea what this could be.
Sorry I was in Vaca mode for the holidays. Sorry to hear that the issue is back. I did look into it a little more and found the following on Microsoft answers.
https://answers.microsoft.com/en-us/windows/forum/windows_10-other_settings/display-colors-change-after-installing-fall/8a235d25-5aaa-4122-8180-4b12efc8a9eb?auth=1
Sounds like rolling back the update and looking for the update again should fix the issue.
https://linustechtips.com/topic/879033-display-driver-problem/#findComment-10887056
