I have cgminer working on my main computer, but on the computer that I just built it is not cooperating. I have tried different amd drivers (currently on 13.11 beta). The error that cgminer throws that disables both the gpu is " error  -4 enqueueing kernel onto command queue".
This is really starting to get annoying since iv'e been trying to fix this for a couple days.
The rig in question has an a10 5800k, (gpu is disabled right now so I could eliminate that), 4Gb ram, old hdd running win 7 32bit. cgminer 3.4.0
Main rig: Coursair Air 540, Amd 8120(stock clock, had it up to 4.6), Gigabyte 990 fx ud3,  MSI DCU2 r9 280x, seasonic 1000w platinum, Samsung 830 64 GB ssd, Seagate 1tb, 4 GB (2x2) G.Skill,
Secondary: Define r4, Amd A10 5800k(4.6), 1x Sapphire 7950, MSI FM2-A85xa, 8 GB coursair vengeance ram, Seasonic 1250w Gold, 500GB 840 Evo, 223GB 2.5 Hdd, 80 Gb Seasonic, Samsung CD/dvd
https://linustechtips.com/topic/87873-help-with-cgminer-error/
Try a low TC, and slowly work your way with intervals of 64. 64, 128, 196, 256, 512, etc.
--thread-concurrency 1792
What GPU are you running?
You keep using that word. I do not think it means what you think it means.
Users cannot, and will not securely manage key material. Most users can't and the ones that can, wont.
Ask me about Bitcoin, Litecoin, Crypto-Currencies, and/or Mining them.
https://linustechtips.com/topic/87873-help-with-cgminer-error/#findComment-1191106
a 7950, which is annoying because in my other computer I have the same card and it runs fine. I was trying to get this card working and then I would put the other card in the new system and my brand new card in my case(since I can only have one mine at a time in the case).
https://linustechtips.com/topic/87873-help-with-cgminer-error/#findComment-1191160
