Cooling connections
Go to solution Solved by RollinLower,
well, i would go for the AIO pump header in this case. i mean, it is specifically made for that purpose. :P
it shouldn't matter too much tough, but AIO pump headers are more fine tuned for the sometimes hard to drive AIO pumps i believe.
https://linustechtips.com/topic/878164-cooling-connections/#findComment-10864973
If you use the AIO_PUMP header, be sure to disable monitoring on the CPU fan header in BIOS.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/878164-cooling-connections/#findComment-10865046
