The cable for my keyboard is completely modular, however, I am looking to get one that can be purchased at custom (or different) lengths, and preferably has nice sleeving. I checked CableMod, but I didn't see anything on there that i wanted. It's possible that I just missed what I was looking for. Where would you look to purchase such an item?
https://linustechtips.com/topic/877977-custom-usb-cable/
44 minutes ago, Himommies said:
Oh wait... I found a picture of it online here https://www.newegg.com/Product/Product.aspx?Item=9SIA4RE6416239&cm_re=corsair_k65_cherry_mx_red-_-23-816-037-_-Product.
It isn't the same on both ends, the one is smaller, and I am unable to find the exact name of the port
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863508
Looks like mini b to me, although send a close up picture so I can be sure. You could sleeve your own cable. IE buy a cheap cable and some sleeving from somewhere (not paracord as its wont fit over the connector) and stretch it over, then heatshrink. Or you could build your own cable from scratch if thats your bag.
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863588
2 minutes ago, unknownmiscreant said:
-snip-
My girlfriend's son is currently using my phone, but if I remember I will send one tomorrow, and I've never made a custom cable before. Although it is something I would like to learn how to do in the future, for right now, I think I would rather just purchase one.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863596
Go here: https://www.mimic-cables.com/products/custom-usb-cable
Select USB A for 1st,  USB Mini for 2nd (It's USB Mini B, but they just call it USB Mini).  Pick your sleeving, colors, and you're off to the races.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863608
Making a custom cable from scratch is probably not the best option here. Usb stuff can be a pain to work with due to the shielding. Although if you don't like other options, sleeving an existing cable with MDPC-X or telios sleeving will be a piece of cake. Look for a video by lutro0 on yt about sleeving sata cables. The cable is different, but it's the same basic method.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863648
Just now, Doomerson said:
Thanks much! I thought "mini-usb" was the same as a standard charger? I assume there an actual semantic difference between "mini" and "micro" in this case?
Yes.  Mini B and Micro B are different.
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863679
1 minute ago, zombienerd said:
-snip-
That is quite the useful image, I just went ahead and saved it. And just to be clear, USB-A is the typical one yes? It looks like it, but I just want to make sure, before I pass this information to someone else.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863687
Yes.  USB A is the standard USB Male computer-end plug that's been used since 1995.
Main Rig:
CPU: Ryzen 5 3600
Monitors: AOC C24G1
OS: Pop! 21.04
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10863692
6 hours ago, Doomerson said:
Thanks, I'm actually going to check that one out now before sleep :D
Just make sure the sleeving you pick can fit over the connector. You may well need the larger 'sata' style sleeving, as the more common size for sleeving PSU cables may not be big enough.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10864583
Worst case scenario you could always buy the Flex Sleeving that has a massive expand ability. They can fit over USB 3.0 headers at the larger sizes they sell.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10865517
Although what diameter can it stretch down to? As I have some 24 pin ATX sleeving that only gets down to 10-15mm.
Main rig:
Crosshair VI Hero
EK Supremacy Evo
Asus Strix Soar
Laptop:
Dell E6430s
16GB 1600MHz DDR3.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10867987
It's massive(Just depends on the size you pick, since it comes in dozen different sizes). It only sleeving I've seen that can expand that large.
https://linustechtips.com/topic/877977-custom-usb-cable/#findComment-10869008
