1. Budget & Location
Under $1000, Missouri, United States
2. Aim
Run handbrake, plex server, 3d printer, storage.
Side note: This is not my main computer. I have a gaming computer. This is to run all the "other" stuff so my gaming computer is free.
3. Monitors
Already have
4. Peripherals
already have
5. Why are you upgrading?
I was dumb and tried to go cheap on my original build and now the parts are "old" and expensive, as in motherboards that I could find cost $350. The TMPIN2 if not thermal throttled, which I found out after bios update, will get up to 104C or if I have safe temp limit set it will cause system to thermal throttle at stock speeds while running handbrake.
Original build I attached as picture, have 500gb SSD as primary drive
6. What I am planning on getting
https://secure.newegg.com/Wishlist/SharedWishlistDetail?ID=nf3T9rLQ86PBGNSMoRLiPA%3D%3D
BTW, I really like the case, I have one for my gaming pc but willing to get something else if a better solution. I love the hot swap bay.
*Edit* will be putting 500GB SSD from old system into new system. Also, I have a GTX 960 I plan on putting in new system mainly just for Folding @ Home.
I appreciate any help.
Edited by J_M_O_
https://linustechtips.com/topic/877522-ryzen-1600-build-help/
Here's my take on your budget. You don't need an aftermarket cooler for Zen.
PCPartPicker part list: https://pcpartpicker.com/list/rf8hnn
Price breakdown by merchant: https://pcpartpicker.com/list/rf8hnn/by_merchant/
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($201.98 @ Newegg)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard  ($93.98 @ Newegg)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($169.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($84.99 @ Newegg)
Video Card: MSI - Radeon RX 580 4GB ARMOR OC Video Card  ($264.98 @ Newegg)
Case: Fractal Design - Meshify C ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($52.99 @ Newegg)
Total: $948.90
Generated by PCPartPicker 2017-12-25 21:48 EST-0500
??? Wanna join ??? my free??gift card??? giveaway??? Click ⤵ the subrscribe button?? ,turn? the notifications on ??? and finally leave a nice comment ??down below⬇⬇ , now without further adue ??? lets get on?? with the video▶▶
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859706
Your Newegg wishlist build looks nice, the only thing I'd probably change is going for the Killer SLI/ac instead of the Fatality.  It's $10 less, has better VRM's, and includes AC wifi on board.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859707
-Swoosh-
Here's one with a cooler for OCing
PCPartPicker part list: https://pcpartpicker.com/list/BcqYyf
Price breakdown by merchant: https://pcpartpicker.com/list/BcqYyf/by_merchant/
CPU Cooler: Corsair - H100i v2 70.7 CFM Liquid CPU Cooler  ($109.99 @ Newegg)
Video Card: MSI - GeForce GTX 1050 Ti 4GB GAMING X 4G Video Card  ($176.98 @ Newegg)
Total: $970.89
Generated by PCPartPicker 2017-12-25 21:57 EST-0500
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859735
is the pic your old rig?
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859741
Yep
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859744
Total: $970.89
I appreciate your feedback. My only question is how reliable is that cooler? The only reason I ask is because it has several reviews saying the pump dies really quick. I kind of ignored the bad reviews for the motherboard of my old rig and it was a mistake.
I should have made it a little more clear but I plan on installing the 500gb SSD from old rig into the new one. I have a GTX 960 also, that I plan on throwing in the new rig since I shouldn't need much from the video card, mainly just to run Folding @ Home.
I appreciate everybodies help and I am reviewing the suggestions and looking at the reviews and stuff.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859754
4 minutes ago, J_M_O_ said:
Yes, pic is old rig
i'd just recommend this:
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($379.99 @ B&H)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard  ($156.98 @ Newegg)
Memory: GeIL - SUPER LUCE RGB SYNC 16GB (2 x 8GB) DDR4-3000 Memory  ($174.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1050 2GB ACX 2.0 Video Card  ($113.99 @ SuperBiiz)
Total: $825.95
Generated by PCPartPicker 2017-12-25 22:10 EST-0500
reuse the rest of the parts.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859755
Total: $825.95
I have never used pcpartpicker but it gives me this error when going to your link Warning: These parts have potential issues/incompatibilities.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859766
it just says there's no cooler, which you should be able to reuse from your old rig.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859772
When I look at the specs for the processor it says the only supported memory is DDR4-2666. Usually cpu's list several different memory it supports but this one doesn't, does that mean you have to use 2666 speed memory with that cpu?
Just asking because I am more of a novice builder and don't know what can be used with what if not specifically stated. I appreciate the feedback though.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859779
nope, it means cpu can go up to 2666mhz but you can just set XMP profile to the rated speed of the ram you have.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859785
Here's one with no GPU and a better CPU
PCPartPicker part list: https://pcpartpicker.com/list/sFPbNN
Price breakdown by merchant: https://pcpartpicker.com/list/sFPbNN/by_merchant/
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  ($299.99 @ Newegg)
CPU Cooler: Cooler Master - MasterLiquid 240 66.7 CFM Liquid CPU Cooler  ($64.99 @ Newegg)
Motherboard: ASRock - X370 KILLER SLI/ac ATX AM4 Motherboard  ($143.98 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg)
Total: $871.92
Generated by PCPartPicker 2017-12-25 22:30 EST-0500
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859801
Total: $871.92
I notice both you and somebody else recommend the SLI/ac over the Fatal1ty ASRock motherboard. Is there something I am missing. They look pretty close to the same thing except the Fatal1ty is $10 more and has a much better review rating.
Not arguing just a novice and don't know what I am missing.
Still looking through all recommendations, thanks again.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859840
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859854
2 minutes ago, PerfectPlasma said:
I appreciate your patience with me.
I hate wifi so that is not a concern, lol.
With VRM that is referring to the power phase correct? Don't they both have 12 power phase? I know newegg says that SLI/ac has 16 powerphase towards the top but if you scroll down it says it only has 12 power phase. If you go to Asrock website it says both boards are 12 power phase.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859865
FeelsBadMan
It comes with bluetooth as well, incase you use any wireless headphones, etc...
Why do you hate wifi?
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859880
1 minute ago, PerfectPlasma said:
FeelsBadMan
It's not that I hate it, i guess, but I just highly prefer wired connections. Less interference. When I upgrade my "wifi" setup it won't be as bad, just have to pick and choose what I upgrade. Right now I would prefer to upgrade my "home server".
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859888
Here's a build with RGB because why not?
PCPartPicker part list: https://pcpartpicker.com/list/gHQjPs
Price breakdown by merchant: https://pcpartpicker.com/list/gHQjPs/by_merchant/
CPU Cooler: Thermaltake - Water 3.0 Riing RGB 240 40.6 CFM Liquid CPU Cooler  ($116.99 @ Newegg)
Motherboard: Asus - PRIME X370-PRO ATX AM4 Motherboard  ($128.98 @ Newegg)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3000 Memory  ($209.99 @ Newegg)
Case: Thermaltake - View 31 TG RGB ATX Mid Tower Case  ($124.02 @ Newegg)
Total: $992.95
Generated by PCPartPicker 2017-12-25 23:35 EST-0500
Don't actually answer that question pls (:
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10859922
Total: $871.92
You are recommending DDR4-3000 but the motherboard says DDR4 2933+(OC), what do I have to do to get the ram to work with the motherboard?
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10873717
If you can get it at 2800 you'll be fine, the difference between that and 3000 is minimal.
https://linustechtips.com/topic/877522-ryzen-1600-build-help/#findComment-10873804
