Hello so i installed a new gpu into my system but i didn't connect my 6-pin power connector so if i just leave the gpu in there with my pc turned on will it damage the gpu in my pcie x16 slot or no?
and another question, do i HAVE to connect my monitor to the gpu in order to use it?
The GPU is the EVGA geforce 450 GTS in case any of you were wondering it
https://linustechtips.com/topic/87735-help-with-my-gpu/
I don't think you could wreck sit but I would recommend against it as the pc won't run and probably just turn on and off continuously. And in order to use the gpu a cable has to be connected to it.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/87735-help-with-my-gpu/#findComment-1189360
