first pc build help welcome
Go to solution Solved by seon123,
There is a German PCPP site with German prices. Prices vary by country, so a list made with PCPP US won't cost the same in Germany.
For gaming, especially ones not heavily multi threaded, you'll want Coffee.
You can get a Windows key from Reddit or Kinguin for ~€25.
You could easily cut costs by going for an 8400 with the stock cooler, changing the motherboard to a cheaper one (only do this if you get the 8400), getting a 1070 Ti instead of the 1080 Ti, or changing the PSU to a Vengeance or Pure Power 10.
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  (€266.59 @ Alza)
CPU Cooler: Scythe - Mugen 5 Rev. B 51.2 CFM CPU Cooler  (€44.90 @ Caseking)
Motherboard: Asus - Prime Z370-A ATX LGA1151 Motherboard  (€150.89 @ Amazon Deutschland)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  (€182.84 @ Mindfactory)
Storage: Crucial - MX300 525GB 2.5" Solid State Drive  (€139.95 @ Amazon Deutschland)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11GB Gaming OC 11G  Video Card  (€735.99 @ Mindfactory)
Case: Corsair - 270R ATX Mid Tower Case  (€60.99 @ Amazon Deutschland)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€83.90 @ Caseking)
Total: €1666.05
Generated by PCPartPicker 2017-12-23 20:06 CET+0100
Got together some money for a gaming pc
planning current build: https://de.pcpartpicker.com/list/d9Nd4C (thx seon123)
Budget: 1300€ - 1700€ (1550$ - 2000$)
(Location: Germany)
Aim: Gaming - Indie - Minecraft (200+ mods)
Monitors: from old pc & wanting to upgrade to 2x 1080p
peripherals: from old pc
Case: don't care (black)
OS: need Win10
Upgrade reason: no gaming pc
https://linustechtips.com/topic/876616-first-pc-build-help-welcome/
Total: €1666.05
Total: €1666.05
Honestly. seon123 made a very solid build. i wouldn't change a thing except for maybe the cooler to this (Cooler master HyperX 212).
The 212 is not really a very good cooler in general. The cheaper M9 and Pure Rock Slim perform the same, while being cheaper and smaller. The Mugen 5 is a nicer cooler, and should be fine for an overclocked 8600K.
Really? I've read many good things about the 212. Honestly though, i never had one and you made a really good build, so you probably are right.
