I just install my brand new ssd
So i was thinking i wanna put the new windows in ssd but i dont wanna lose the files in my hdd i dont like to format the whole drive coz i have some important files overthere so my question is
Can i install new win on the ssd and just manually delete the old one on the hard without losing any of the files,and do i have to reinstall all the steam battle net apps and then relocated all the games
https://linustechtips.com/topic/876041-ssd-help/
You can install Windows fresh onto the SSD without any interference - just make sure the hard drive is unplugged somehow during this process. Windows can sometimes perform some weirdness during this process, even if you specifically state for Windows to be on the SSD.
For your games, Steam and Battle.net should be able to detect your games fine when adding the folders.
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847925
Do i need to install any aditional drivers ? when i put new win i did it kinda long agoo :(
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847941
You shouldn't have to do any additional work. Though you may want to verify it if you have anything other than a standard SATA SSD.
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847945
Also i can then manually delete the old windows ? from the hdd
You should be able to as long as Windows doesn't do any weird nonsense(seriously unplug it when installing Windows fresh onto the SSD).
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847950
Can i just unplug from the mobo coz i got the corsair rx460 the cable managment is hell i just re do it the whole thing
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847958
Yeah, that's not an issue.
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847959
5 minutes ago, Aowek955 said:
Also i would need to reinsall apps like torrent battlenet and steam gog origin on the ssd right ?
Yeah, most likely.
https://linustechtips.com/topic/876041-ssd-help/#findComment-10847991
11 hours ago, Aowek955 said:
It wont let me install win on ssd coz it gdt partion i tried changing it to msb disk still says cant install what shouild i do ?
Remove the partition and re-create it within the Windows installer.
https://linustechtips.com/topic/876041-ssd-help/#findComment-10849174
