Motherboard replacement
Solved by JustAStrangeGeek,
1 hour ago, Shark07 said:One final question...
Gigabyte ga z97 hd3 or asrock z97 extreme6
I recommend the Gigabyte GA-z97 HD3 over the extreme6 mainly because the hd3 has support for appcenter which allows you to easily tune your cpu frequency and the like (through a plugin) as well as the @bios utility (also a plugin) that allows one to update the bios throughout the Windows environment.
If you do update the bios and you end up bricking it (the board will be basically dead), the gigabyte board supports dual bios (which the as rock board lacks) In the case of the previously mentioned 'bricking your board', just clear the cmos and your back to normal.
- JustAStrangeGeek
