Hey guys, just a quick question, do any of you know where I can get some mesh like the stuff that comes on top of disposable BBQs like the one linked in the UK. I'm planning to use it to mod a computer case.
https://www.amazon.co.uk/Fuel-Express-Instant-Disposable-Barbeque/dp/B007V1MRSY/ref=sr_1_6?ie=UTF8&qid=1513548860&sr=8-6&keywords=disposable+barbecue
P.S. I wasn't sure whether to put this here or if another section fitted better, any Mod feel free to move if needed.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/874470-mesh/
1 minute ago, qakawra said:
the closest thing i can think of is chicken wire, but that may have too wide of holes for your project
Just now, qakawra said:
uhm...
try searching up wire mesh
I have tried searching the internet but i cant seem to find the exact thing I need, my local hardware store doesn't seem to sell it so I'm going to try the big one in town tomorrow, I was just going to take it from the BBQ but its not a big enough single piece. I was more hoping someone would be able to tell me if it has a specific name.
https://linustechtips.com/topic/874470-mesh/#findComment-10833407
Thanks, I really appreciate you taking the time to help, but the BBQ mesh is much thicker than this material, almost like its holes punched into sheet metal.
https://linustechtips.com/topic/874470-mesh/#findComment-10833433
https://linustechtips.com/topic/874470-mesh/#findComment-10833508
Microwave doors are likely the cheapest, but have very fine mesh.
See this post for some more detail:
Sync RGB fans with motherboard RGB header.
Main rig:
Ryzen 7 1700x (4.05GHz)
EVGA GTX 1070 FTW ACX 3.0
16GB G. Skill Flare X 3466MHz CL14
Crosshair VI Hero
EK Supremacy Evo
EVGA SuperNova 850 G2
Intel 540s 240GB, Intel 520 240GB + WD Black 500GB
Corsair Crystal Series 460x
Asus Strix Soar
Laptop:
Dell E6430s
i7-3520M + On board GPU
16GB 1600MHz DDR3.
https://linustechtips.com/topic/874470-mesh/#findComment-10834238
Thanks, although a microwave door would not be anywhere near enough as i am planning to do the Gamers Nexus style meshify mod to a H500P. I'm really liking The Mesh Company they are only up the road from me pretty much so I will be supporting a local business and get it cut to order.
https://linustechtips.com/topic/874470-mesh/#findComment-10835224
  • 3 weeks later...
1 minute ago, Cazan said:
I'm not sure why you've posted this man as I already knew what I was doing, it was just the type of mesh I needed help with.
Thanks anyway though.
https://linustechtips.com/topic/874470-mesh/#findComment-10902079
