I've come back to my pc after 3 months. Updated windows and then went to update my graphic card drivers. I have a AMD 390X. Couldn't find how to update them via the software so I decided to download them off the AMD site.
Before I downloaded the driver I used the AMD uninstall program in the driver files so I could start from fresh. Ran the program and restarted my PC.
The problem is the new drivers won't install. Once I press install on the driver it'll appear in task manager for a while and then disappear. Any ideas
Specs
i5 6600k
AMD R9 390x
https://linustechtips.com/topic/874464-amd-driver-problem/
6 minutes ago, JustAStrangeGeek said:
Here is the link that cj09beira was talking about
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Tried that and wen't to re-download and install and still the same problem, and yes I used 64 bit
https://linustechtips.com/topic/874464-amd-driver-problem/#findComment-10833047
It just places the files in the install location, stays as a open task in task manager for about 1 minute and then just goes
https://linustechtips.com/topic/874464-amd-driver-problem/#findComment-10833053
