PWM Fan Controller
Solved by N7_Zer0,
Anyone have experience with 4-pin PWM fans (such as AF140s) having variable speed control through a fan controller?
I wanted to pick up a NZXT SentryMix2 for my AF140s but I would love to retain the ability to actually change the speed despite these fans being pwm.
Not sure if this fan controller will vary the speed since pwm fans usually need a constant 12V.
Thoughts?
A PWM fan has 4 pins (ground, 12v, rpm sensor, pwm). Using a PWM fan on a 3 or 2 pin connector (as with the NZXT controller) will turn i into an ordinary non-PWM fan which you can adjust the speed via voltage. How low a voltage you can go before it stalls depends on the fan.
