I found a old backup wallet that is around 200-300 lines of letters/numbers total number of character must be in the thousands. If someone can help me restore this I will be willing to share 10% of the amount. I have tried putting it into Bitcoin Wallet and it appears to not be valid for bitcoin wallet.
U2 are the first letters. I don't remember which program it was a backup for the backup it saved doesn't have a file extension and the file name ends with the date it was backed up on.
It appears they follow a sequence of letters and numbers followed by a "/" then some random "+" here and there and goes on for 200-300 lines.
OS: Windows 10 Pro
CPU: AMD Ryzen Threadripper 1950X
Cooling: Enermax LiqTech 360mm TR4
Motherboard: AORUS X399 Gaming 7
PSU: Corsair RM1000i
RAM: 32 GB G.Skill Trident Z RGB 3600MHz
M.2: 250GB Samsung 960 EVO
GPU: AORUS GeForce GTX 1080 8GB Xtreme OC Edition
https://linustechtips.com/topic/873014-help-please-need-help-with-backup-key/
well, what cryptocurrencies have you used?
Main rig                             I also got some cheep lg phone and a chromebook, witch I have been known to mine bitcoin on sometimes
CPU: R5 2400g
RAM: 8gb ram
MOBO: msi b350 pc mate
CASE: Eclipse p300
PSU: 500w corsair
