So basically I am looking into buying a new PC (building myself) and I was wondering if it would be possible to reuse my HDD. Would I need to uninstall windows from it? And If so how? Or if not what would I need to do. Or can I not reuse the HDD. Also, I know that I will lose files, I will back them up so it's fine.
I hope someone can help me!
Many Thanks, Josh
https://linustechtips.com/topic/872843-help-with-hdd/
you can reuse the HDD. I would just format it completely AFTER windows is installed on the SSD.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/872843-help-with-hdd/#findComment-10818691
you can reuse an old drive as long as its working, however please note that HDD's are ticking time bombs, even the new ones and you never know when its going to go off, so yea as long as you backup then why not ?
Microsoft in there infinite wisdom have decided to impose a VRAM cap for games the that use DX9 o.O. May God Bless them those whoever came up with that idea. :dry:
You're looking for something that does not, has not, will not, might not or must not exist ... ... but you're always welcome to search for it.
https://linustechtips.com/topic/872843-help-with-hdd/#findComment-10818730
Storage is perfectly reusable so long as it's healthy. You can run diagnostic software on the drive to check on it's health first, we have a free one called SeaTools. You've already mentioned a lot about what's important/how to go about it. Best plan of attack is back up your data to some other storage medium like an external drive/cloud, then disconnect the hard drive, boot with only SSD attached and either OS installation CD or bootable media installer using the Windows' Media Creation Tool, then after you've got your OS alive and kicking on the SSD, format the old hard drive.
Seagate Technology | Official Forums Team
IronWolf Drives for NAS Applications - SkyHawk Drives for Surveillance Applications - BarraCuda Drives for PC & Gaming
https://linustechtips.com/topic/872843-help-with-hdd/#findComment-10818737
