Hey boys, so lately my PC has been very sluggish sometimes.
It can get so bad that the system becomes nearly unusable. Right before this it took 10 seconds to bring up the menu when I pressed CTRL-ALT-DEL.
Here's a screenshot of my total RAM usage according to Rainmeter, compared to usage %s in Task manager.
I'm really not sure what's causing it or what to do.
Using W10.
CPU: 4770K @ 4 GHZ
GPU: 980ti
RAM: 16GB DDR3 1866 MHz
Any help would be greatly appreciated as if I can't figure out what this is being caused by I'm probably just going to wipe all my drives and do a fresh install (I'm really trying to avoid that, lots of data to backup/redownload and I'll undoubtedly forget some obscure file that ends up being important in a backup).
https://linustechtips.com/topic/872675-problems-with-pc-sluggishnessram-usage/
Using W10.
CPU: 4770K @ 4 GHZ
GPU: 980ti
have you tried a clean windows boot?
Have you tried to perform a sudden temporary interrupt of the electricity flow to your computational device followed by a re-initialization procedure of the central processing unit and associated components?
Personal Rig Specs
CPU: Intel Core i7-7700K @ 4.8GHZ
Motherboard: Asus ROG STRIX Z270H GAMING
Graphics Card: Inno3D ICHILL GEFORCE GTX 1080 TI X3 ULTRA
RAM: Corsair Vengeance LPX Black DDR4 2x8GB @ 3GHZ
Storage: 2 x Samsung NVMe SSD 960 EVO 256GB in Raid | 2 x Seagate 4TB Expansion Desktop
(seagates are originally external drives removed from casing and installed internally)
PSU: Seasonic Prime Titanium 850W
Case: Mission SG GGX 3.5 (same as Rosewill Cullinan or Anidees AI Crystal with other stock fans)
Cooling: Kraken X62 for CPU, Corsair H55 with NZXT Kraken G12 for GPU
As in a new windows install? No, I'm hoping to avoid having to do that.
16 hours ago, kittyducky06 said:
yes you have a lot f programs taking ram just try a reset
Processes. At the time I had like 2 programs open lmao.
4 hours ago, kittyducky06 said:
one of those i taking 200mb of ram
google chrome doesnt even use that
You're right, it doesn't use 200mb. It uses 10 GB. :^^^^^^^^^)
3 hours ago, vaiwalker said:
try a clean boot. probably just a program eating up resources.
As in restarting my PC?
1 hour ago, TheGreatWizardCalder said:
As in restarting / reinstalling my PC?
no, as in clean boot:
https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows
Personal Rig Specs
