FreeSync AND VSync?
By
Noyu
in Graphics Cards
in Graphics Cards
Solved by Vode,
Forget V-Sync.
With the newest AMD Adrenalin drivers you'll get Enhanced Sync. It's a better alternative to V-Sync.
Also yes you can use those at the same time. Although Enhanced Sync only comes into play when you have higher FPS than your display can handle.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory1 -
derekchan ·
Posted in New Builds and Planning6 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting8
play_circle_filled
Latest From ShortCircuit:
