What's your system specs?
What exactly do you mean shaky ect? Did you want to record a bit and post it here so we can get an idea?
Ill trie to make a video, but by shaky i mean like if the refresh rate was not ''right''. It was fine before, so it might be the new Nvidia Driver to..
I'm playing on my second monitor, a large samsung 27 inch 1080p monitor. Never had any issue with it.
My spec (its a laptop, the Msi Gt60) :
Windows 8 64-bit
Intel Core i7-3630QM
12 gig of ram
intel hd 4000
Nvidia gtx 675m : I had issue launching the game first because jc2 was confuse with my 2 gpu, so i had to 700g hdd put a command line in the launch option to fix it.
EDIT : i tried to screen cap it, but in the video the problem don't occure. I film this : http://youtu.be/KJsLPfFAqmQ with my ipad but it was diffcult to show on the camera what i'm seeing with my eyes. i have two thing that comme in mind, 1 is that the refresh rate is not ok, or 2 is that the resolution is in 1080i instead of 1080p.
https://linustechtips.com/topic/8721-just-cause-2-issue/#findComment-97177
  • 4 weeks later...
