Hello everyone! Long time lurker, first time poster.
I currently have a Surface Book 1 with the GPU base.  At first I loved it and it was flawless in my eyes, but eventually firmware updates seem to have caused so many issues I'm wanting to sell it and get a replacement for it.
I use this thing for almost anything (programming, video editing, gaming, and more).
Some of the things I want in a replacement would be,
decent gaming in 1080p (doesn't have to be a full fledged gaming laptop)
Good performance in video editing
Touch screen
lightweight
Foldable (similar to if the surface book screen detached)
I'm going to use whatever money I get for the SB1 to buy the new one. I'm looking for any advice.  I won't touch Lenovo's or HP's so don't bother recommending those.
Thanks in advance.
https://linustechtips.com/topic/871819-surface-book-replacement/
Just now, Brambo said:
I currently have 256gb and it's manageable.  I would like more storage but this is probably something I can let slide.
Get one of these, probably one with the 7700HQ and the either 256Gb SSD or the 512Gb SSD (Lenovo Yoga 720 15").  It is a touch screen 2 in 1 with a 1050 and a 7700HQ, and has TB3.  Get a Razer Core and the GPU of your choosing and you should be set.
Would a Dell XPS with a Razer core be almost equal?
I assume you mean the XPS 13 2 in 1.
No, it wouldn't.   The XPS 13 2 in 1 uses a 15W CPU, which is slow as shit.  For gaming and demanding tasks, you want a beefier CPU.
Didn't even notice that!
Is it basically Lenovo that owns this type of market?
I'm fairly sure this is the only 2-in-1 with a 45W CPU on the market, so yeah they own this  segment :) .  Combining the Lenovo that I suggested and a Razer Core is the closest you'll get to what you had with the Surface Book.  It'll probably outperform what you had before.
That sounds like a lot of setup compared to what I have now.  I guess I'll try and troubleshoot the SB again and see if there is anything I can do to make it work properly.
Thanks for the help everyone!
