I just got an h320 and I have amd and I have it all set up but they said I just need the backplate and it does show how to install the water block because if I screw in the backplate then the wholes obviously or blocked where I would screw in water block so I dnt know what to do and how to install please help me if anyone knows how to for amd
https://linustechtips.com/topic/87070-h320-installation-amd-problems/
I know that's what I was referring to all it has is one picture and it doesn't help me at all and the backplate is in place just not screwed in because I do not know how the water block would screw in if the holes are already covered my screws obviously so I clueless on how to install it
