Hello everyone ! I have issue where occasionally (not all the time!)  horizontal lines (most of the time they are white) appear on my screen. It happens mostly when playing video games(in some games more than others  and they are more noticeable in darker scenes, but sometimes also while watching videos. I tried to change graphics driver, i have noticed this issue on two monitors ( one is older LG model, the other is brand new monitor that just came ) and on both monitors same thing so i assume this problem isn't related to monitor, also i tried to plug in different hdmi and dvi cable but it didn't help.
The card i have is https://www.gigabyte.com/Graphics-Card/GV-N105TOC-4GL#kf and the card and pc( 8gb ddr4, i5 7400, lcpower420 bronze80 , Wdblue 1tb) are old around 3 months.
I highly suggest you to watch these two videos ( i've collected footage in Skyrim because there is most noticeable, like i said above these lines does  in some other games and sometimes while watching videos) that i've uploaded because they really describe the issue.
I never had this problem i tried to google around but i was unsuccessful, so please help me if you know something about this!
Thanks in advance!
https://linustechtips.com/topic/869594-weird-gpu-issue/
Did you overclock the GPU in any way?
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/869594-weird-gpu-issue/#findComment-10787938
Yeah, i also think that is quite odd and confusing, In Skyrim those lines occur most of the time in loading screens, in Football Manager they occur quite often actaully ( which is suprising to me because that game isn't that hardware demanding, while in other demanding games like The Witcher 3, Doom,f1 2016, Warfarme i haven't noticed any issues.
Maybe this is somehow related to these two games, but on the other hand i notice this in videos but very rarely.
https://linustechtips.com/topic/869594-weird-gpu-issue/#findComment-10788028
Looks like a video memory issue. I had similar problem showing on a GTX 960 just before it died (aka put out green checkerboard artifacts on the screed at any given time). Did your issues get progressively worse? If so, your vram might be on its way out. I hope your card is still covered under warranty.
https://linustechtips.com/topic/869594-weird-gpu-issue/#findComment-10788042
Well, before you concider rmaing your gpu try fiddling with the display cable maybe? It might be your monitors fault but I highly doubt that.
https://linustechtips.com/topic/869594-weird-gpu-issue/#findComment-10788049
@black0utm1rage yes it is under warranty, and so far i don't think that they are getting progressively worse altought that could change in the future but i don't know.
@black0utm1rage @Konrad Kwasniewski at first i tought it's monitor, u know it was old etc. , but than i bought new monitor ( i planned that anyways) and same thing. Only thing i can do to be 100% sure  is to use these monitors on my old pc but i think that isn't necessary because it's really highly unlikely that both monitors have same issue ( old and new one) and also it's kinda problematic because these lines don't occur all the time.
https://linustechtips.com/topic/869594-weird-gpu-issue/#findComment-10788099
