16 minutes ago, WhyAlwaysMe said:
My ryzen 5 1500x started spiking in temps while idle since I overclocked it to 3.9ghz@ 1.375v. It jumps from 33ºC to 43ºC in less than a second, before slowly dropping back down to 33ºC. I put all fan speeds at 100% to keep cooling constant as well.
What are you using to monitor the temps
That sounds normal to me.
What are you temps during stress testing?
As long as you are under 75°C on Ryzen, I wouldn't worry about it at all.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
Normal, set the fan curve so they wont react to the spiking.
Well if the fans are at 100 even at idle, which makes no sense, you cant stop the temps from spiking. Don't really see the issue.
Do you have Ryzen Master open? Have you tried opening msconfig (Start Menu - Run) and temporarily disabling everything in startup along with unnecessary non-microsoft services? At 'true' idle, your cpu should sit in the lower 30s.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
13 hours ago, WhyAlwaysMe said:
They are around 70-75ºC on prime95 after an hour
That's fine.
WD My Cloud 4TB
