Need help with CSS
Go to solution Solved by Ddave,
At the moment I can't think of possible reasons as to why your styles are not being applied.
What I suggest you do is Inspect the h5 element to see what style is being used.
See screenshot:
The style highlighted with yellow is being overridden by the one underlined with red.
This might help you pinpoint what the problem is.
Hey guys,
I have the problem currently(I am using bootstrap too) that when I use a heading f.e. h1,h2,h3 or any other I am not able to change the color of it.
For information the header is under these parent tags:
<body>
  <div class="tab-content">
    <div class="tab-pane">
      <h5>Test</h5>
    </div>
  </div>
</body>
I tried following steps:
-- Tried to force the color onto the hearder, but didnt work:
<h5 style="color:white;"> </h5>
--I tired to use class from another css. Importantly when setting the link references the other css is under bootstrap so it should override its properties, but did not work either:
inside a css file:
.test{
	color:white;
in the html file:
<h5 class="test"><h5>
-Tried to make a style for it inside the body, but didnt work either:
  <body>
    <style>
    h5{
      	color: white;
    </style>
  </body>
 -Also tried to force override the h5 settings with inside a css file:
  h5{
  color:white;
I also tried to find out if the parent tags force any color onto it through bootstrap but neither .tab-content nor .tab.pane do changes to color(font-color) or anything. I am a little bit at a loss because I dont know a way without changing it inside the bootstrap file, to get around it rn and I dont want to change any source code for now for late porpuses of the headings.
Anybody got an idea what I can do?
Nice Greets,
Rocki
https://linustechtips.com/topic/869478-need-help-with-css/
Use a colon in the css style:
color:white;
Edit: Move along, reading post again.
Edited by Ddave
No sleep, didn't read.
CPU: Intel i5-4590 | Motherboard: Asus H97M-E | GPU: Sapphire Nitro R9 390 | RAM: 2x4Gb Kingston HyperX Fury Black | SSD: Sandisk Plus 240Gb HDD: Seagate 250Gb  | PSU: Seasonic G650 80+ Gold | Case: NZXT S340
I am who I am.
https://linustechtips.com/topic/869478-need-help-with-css/#findComment-10786794
4 minutes ago, Dujith said:
you'll need to create a "sub" class for h5.
So in your case
.test h5 {
color: white;
Then you can use that class with h5
I came up with that already:
.sph h5{
  color:#cfd8ef;
  font-family:serif;
  font-style:italic;
  display:inline;
Did not work for me D:
Could give you the whole source code if you want to
https://linustechtips.com/topic/869478-need-help-with-css/#findComment-10786811
10 minutes ago, RockiLocky said:
Would you mind explaining that more in detail I just started programming in css 3days ago ;D
According to your post, this is what you used:
.test{
	color=white;
The "=" should be replaced with ":" otherwise it will not work.
Anyway I did not notice that the last example in your post uses the colon.
I am who I am.
https://linustechtips.com/topic/869478-need-help-with-css/#findComment-10786846
.test{
	color=white;
sry that is my bad for writing fast here I didnt copy and paste anything to this post just wrote up fast. Will fix it. But I did use color: white; in my source code
https://linustechtips.com/topic/869478-need-help-with-css/#findComment-10786852
See screenshot:
I am who I am.
https://linustechtips.com/topic/869478-need-help-with-css/#findComment-10786861
See screenshot:
Thanks will check that out now
https://linustechtips.com/topic/869478-need-help-with-css/#findComment-10786887
