- Moved to Air Cooling -
 CHRISTIAN MEMBER
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780086
9 minutes ago, Yatys 93 said:
yes they will work, you will just need to check that the 4 pin header can do voltage control, these days most can but worth just double checking
I have heard that PWM is superior to voltage control, if I wanted to do PWM, would I need the adapter?
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780206
2 minutes ago, Yatys 93 said:
there is no way to use PWM control on a 3 pin fan, however you are correct PWM is better than voltage, but voltage is better than just being ran at full tilt
That's why I am asking if I could use 3 to 4 pin connector, to use PWM, then use a splitter to use 2 fans on one header
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780231
Just now, mike123159 said:
So unless I get 4 pin fans, I cannot use PWM?
exactly, the 4th pin is used to convey data from the fan (rotation speed) to the controller which then makes decisions based on a parameter (temp) and sends data back to the fan on what to do, speed up slow down or stay the same, without that forth pin on the fan, it can't deal with that data and therefore can not be controlled.
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780273
Oh well then, thanks for your help, I'm very grateful.
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780283
no worried, please note that most 4 pin headers will be able to do voltage control, and that 3 pin fans will plug in fine, the 4th pin will just poke out the side and be ignored, that will keep your pc perfectly cool
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780291
The problem that I had was how loud the fan would be, I just hope that my motherboard has voltage control
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780299
what board do you have? if it doesn't though you can always buy a fan controller, I have one in my old pc as the original motherboard had one header free for all 3 case fans, works great but I have to manually set the speeds every time something changes
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780305
I have the Asrock Killer Sli/Ac z270 Motherboard
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780319
reading through the manual, all the headers on your board support 3 pin voltage control, also you can use the "chassis optional / water pump header as a normal fan header instead of using a splitter, once there all connected, quickly enter the BIOS to check they are set to DC / voltage, which it should have done automatically and your good to go, you can set them to there quiet profile while your there.
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780334
You are a life saver my friend, Thank you for all your help :)
https://linustechtips.com/topic/868772-case-fans-problem/#findComment-10780341
