From the 30 seconds of research I just did, it seems like it's either a motherboard or CPU issue. Try clearing CMOS.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/868650-help-mobo-switch-issues/#findComment-10778989
possibly, your mobo needs an UEFI update to accept the devils canyon platform over the haswell platform.
if you do not have the older haswell CPU, you can use BIOSFLASHBACK feature to update to newer UEFI.
https://www.asus.com/us/Motherboards/MAXIMUS_VI_IMPACT/HelpDesk_Download/
version 1505
Quote
*Before using the new Intel 4th Gen Core processors, we suggest that you first update the BIOS using USB BIOS flashback, or download the BIOS updater for new Intel 4th Gen Core Processors and then update the BIOS using it.
https://linustechtips.com/topic/868650-help-mobo-switch-issues/#findComment-10779078
version 1505
I’m going to try this. How do you update it? Like where do you download it to?
https://linustechtips.com/topic/868650-help-mobo-switch-issues/#findComment-10779227
56 minutes ago, CPPrince said:
Yeah already tried and no post. Turns the monitor on but nothing more. Display port cable.
I'd assume there's something wrong with it. If you can, try updating the BIOS.
SPECS:
https://linustechtips.com/topic/868650-help-mobo-switch-issues/#findComment-10779248
