thermal paste replacement idea
Sorry if this seems trolly and admin remove if not appropriate I'm not trolling g'day I'm new to the forum. and i had a random thought and wanted to know the answer. instead of using thermal paste couldn't "Flux" or Flux Gel" be a liable solution (as a temporary solution) if you don't happen to have thermal paste. because the main reason for flux gel i've used it for as dissipate heat when replacing parts in a circuit board and the per pose for thermal paste is the same to make contact with heat sink. give me reasons to why this would work or wouldn't work thanks.
https://linustechtips.com/topic/868486-thermal-paste-replacement-idea/
