why the 7600k? get a ryzen 1600 or coffee lake i5 instead.
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773946
Just now, Team Aqua said:
why that
the 7600k has little upgrade path and old, while the 1600 and coffee lake i5s performs better and still have upgrade paths.
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773953
what you meen whit upgrade paths,
how much you can upgrade the cpu to without replacing the motherboard.
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773962
That's true, but I do not think I will want to upgrade the cpu. I think I will upgrade the motherboard and cpu at the same time if I want to, but do you know any good CPU cooler
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773964
14 minutes ago, Team Aqua said:
I am planing to build a gaming pc whit a intel core i5 7600k, and I wonder wich cpu cooler I should get, I want it to be quiet and work in a mini itx case, thermatake core v1 snow edition
Out of interest, what else is going in the build? Would always suggest the Corsair H100i V2 Or the Corsair H80i V2 if you're limited for space...
However, i haven't had much experience with any other coolers but the corsair ones have been perfect for keeping the cpu cool and they are rather quiet. Also have some RGB lighting if you're into that
Case: Lian-Li PC-011 Dynamic  CPUi7-7700k (4.8ghz) CPU Cooler: Corsair H100i V2 Case Fans: 5x ML120 RGB / 2x LL120  GPU: Aorus RTX 2080 Xtreme Motherboard: ASUS ROG STRIX Z270H RAM: 32GB Corsair Vengeance RGB Pro DDR4 (3200mhz) Storage: 2x 1TB SG Barracuda, 128gb BiWin M.2 SSD PSU: Corsair RM650x OS: Windows 10
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773969
even if you don't want to upgrade the CPU, the ryzen 1600 performs better for a similar price, while having a pretty decent and quiet stock cooler.
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773971
parts:
Intel - Core i5-7600K 3.8GHz Quad-Core Processor
cpu cooler?????????
G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory
I googled the 2 corsair coolers and they were a bit to expensiv for me but
thanks for the help :D
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773977
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773979
Just now, Jaminahat said:
What is your budget? Like @herman mcpootis said, might be better off with a Ryzen system, Especially if you can stick with the stock cooler, that way you might have some extra cash to upgrade to a 6gb 1060 or something similar...
I wana build a pretty good gaming pc for a pretty low price, i am planing to get all the part before the summer, becuase my birth day is before the summer and build it then.
I googled the ryzen cpu and it costa like 10 $ less but it was just 3.2ghz
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773985
Have you got a pcpartpicker link? ill take a look and see what i can do, i understand that price to performance is important to you here
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773992
the 1600 has 2 extra cores with hyperthreading to help make performance better.
the 1600 maintains it's framerates in heavier scenes but the i5 tanks in performance due to the lower core-count.
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773995
ok, thanks I am gonna look on it
but is it only the preformens that are going to be diffrent????????
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10773998
what do you mean?
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10774004
I mean that are it going to be any diffrens of parts that I can choise between, I like intel, and feel safe whit it, I more much more about intel then amd....
some coolers may not have AM4 mounts included, but you can usually order them from the manufacturer's website.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($189.98 @ SuperBiiz)
Motherboard: ASRock - AB350 Gaming-ITX/ac Mini ITX AM4 Motherboard  ($106.89 @ OutletPC)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($92.88 @ OutletPC)
Storage: SanDisk - X400 256GB 2.5" Solid State Drive  ($69.99 @ Newegg Marketplace)
Storage: Toshiba - P300 1TB 3.5" 7200RPM Internal Hard Drive  ($39.88 @ Other World Computing)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  ($259.99 @ B&H)
Case: Thermaltake - Core V1 Snow Edition Mini ITX Tower Case  ($51.33 @ Amazon)
Power Supply: SeaSonic - FOCUS Plus Gold 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($54.90 @ Newegg)
Total: $865.84
Generated by PCPartPicker 2017-12-02 07:21 EST-0500
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10774009
8 minutes ago, Team Aqua said:
I think this is the link:
https://pcpartpicker.com/list/pqwgRG
https://pcpartpicker.com/list/4CkJsJ
Here is my attempt, you may have to spend a bit more but itll be worth it...
Total: $865.84
Looks like we are on the same wavelength... xD
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10774013
Total: $865.84
I will Probably
record / edit videos
play games like:
minecraft
scrap mechanic
roblox
astroneer.
wich cpu will be best for this
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10774015
I will Probably
play games like:
minecraft
scrap mechanic
roblox
astroneer.
the 1600 would be better.
https://linustechtips.com/topic/868067-wich-cpu-cooler/#findComment-10774019
