Hi everyone...
So recently I bought  a new msi b350 PC mate motherboard .. only recently when I boot my PC it keeps saying select booting device and when I set my boot correctly and restart and safe,it does boot but it says the same thing,I feel like it's the bios is reseting  after each on/off switch... People say I need to replace my CMOS battery.
But now I'm curious,when I do that, will changing my CMOS battery void my warranty?
I did unplug everything and plugged it back in,it does the same...
https://linustechtips.com/topic/868004-cmos-battery/
No, changing the battery won't void anything.  It's intentionally made removable so you can replace it when it's empty.
It's a standard CR2032 lithium battery you can buy from lots of places.
Example :  4 for 5$  or 2 for 3.75$ : https://www.amazon.com/Energizer-Electronic-Specialty-Battery-2032BP4/dp/B00D8P5T0U/
https://linustechtips.com/topic/868004-cmos-battery/#findComment-10773547
