What do you mean by fixing? Could anything have gone haywire afterwards?
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
well, when I got it, nothing happened at all, wouldn't post, wouldnt do anything. after cleaning the inside, it turned on, but after the second boot, the power led would blink one and turn off.
1 hour ago, Master Jorn said:
So im fixing my friends macbook pro 2010, it receives power, but when i press the power button the power led flashes for 0.5 seconds and turns of again.
Try resetting the SMC on your mac.
https://support.apple.com/en-ca/HT201295
  1. Using the built-in keyboard, press Shift-Control-Option on the left side of the keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
    If you have a MacBook Pro with Touch ID, the Touch ID button is also the power button.
  2. Release all keys.
  3. Press the power button again to turn on your Mac.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
