settings>system>storage: change where new content is saved. also redirect desktop, documents, downloads, etc to your storage drive as well. My os drive is 60gb filled and that's with a couple ~10 gb programs so you don't need a large ssd, just be mindful of what you put on it
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/866260-ssd-help/#findComment-10756467
Just going to casually Hi-Jack this thread. Is it possible then to set it so downloading specific filetypes default to going on different drives?
CPU: R5 3600 @ 4.4 GHz
RAM: 16GB DDR4 @ 3200 MHz
GPU: RTX 2080 Super
https://linustechtips.com/topic/866260-ssd-help/#findComment-10756575
well you can set a download directory through your browser, only way I know to have different files go different places is to manage that manually
desktop
HTPC
https://linustechtips.com/topic/866260-ssd-help/#findComment-10758079
  • 2 weeks later...
48 minutes ago, Extreme Striker said:
Where should i put photos music videos etc, as i've heard that ssd's don't really like getting written constantly do i just put those on my hdd? Thanks
I keep them on my hdd, they don't need faster storage unless you're doing video editing
desktop
HTPC
https://linustechtips.com/topic/866260-ssd-help/#findComment-10815996
