So I just bought Elder scrolls online tamrieal unlimited from steam and it downloaded a 66.6 GB installer. When ever I launch the installer it dose not give any option to install the game at any other location than my SSD . I have 54 GB on my SSD with windows and it once gave me an option to install it in my steam library but my drive has only 131 gb so with the installer in it I have no way of accommodating 85 GB . any idea on how I install it at any other location?
https://linustechtips.com/topic/865784-elder-scrolls-online-help-required/
I think moving steam to a drive with enough storage space should do the trick.
Desktop
CPUi5-6600K MotherboardGigabyte GA-Z170-HD3P CPU Cooler: Thermalright True Spirit 120M Black/white RAM: Corsair Vengeance LPX 16 GB DDR4 2400Mhz GPU: Gigabyte 1070 HDDs: 2 x Seagate Barracuda 2TB 7200 RPM  SSDSamsung EVO 850 500GB PSU: Coolermaster 550W 80+ Gold Case: NZXT S340 (White) with a white led strip ;)
Laptops
Dell 7577
CPUi7 7700HQ RAM: 16 GB DDR4 2400Mhz GPU: GTX1060 Max-q HDD: 1TB 5400 RPM  SSDNVMe 512GB SCREEN: 4k IPS 15.6"
Macbook pro 2018
CPUi7 RAM: 16 GB DDR4 2400Mhz GPU: Radeon Pro 555X 4GB Storage256GB SCREEN: 15"
moving steam? some times it says install on c and sometimes it says on d but not on the other drive in which I have a library with enough space
I've had a couple that installed that way in Steam, so I had to select the path in Steam before downloading the installer. Create a new Steam folder is you don't already have one on the other drive, then move the install to that directory and try again.
Move it through the Steam app, not file explorer.
I have anew folder what now?
should I install steam in the drive in which I want the game?
@Abdullah Arif, Where is you current Library for Steam is it on your SSD or your HDD? if you have a 2 game libraries on your PC then you going to need to set your one on the HDD as your primary installation point for games. As by the looks the game is trying to install it where the installer is which I'm assuming is on your SSD.
Question do you have Two steam libraries? One on your SSD and one on your HDD?
Some people prefer a challenge, I just band my head against a wall until my method works...
I HAVE 3 LIBRARIES OF WHICH TWO DISPLAY
ive hit upon an ingeneous idea!
move the game to the drive where I want it. move other files from where I moved the game and then install it in the drive! this is gonna take a while:D
