Compact Tripod
Solved by cc143,
Manfrotto, Benro, Mefoto, Sirui all have great travel options that fold down to 35-40cm. With Manfrotto avoid the Befree One (smaller version of the befree).
If I were to recommend a tripod fitting this description though, its more expensive than $100, more like $150 I believe, but the 3 legged thing Corey or the Travis (45cm folded down) are great options.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory1 -
derekchan ·
Posted in New Builds and Planning6 -
5
1
5
kerriya ·
Posted in Cases and Mods9 -
octester ·
Posted in Troubleshooting7
play_circle_filled
Latest From ShortCircuit:
