Newly built PC boot issues.
Go to solution Solved by Crunchy Dragon,
9 minutes ago, HunterScott said:
It powered on outside of the case without any hiccups!
Hmm. Sounds like a standoff problem, make sure all those are installed
Hey guys. I put together a MATX build today as a media streamer/alt computer to tinker with but the darn things refuses to boot.
From time to time, the computer will start for approx. half a second and then cut out. I have tried removing RAM and moving them around the different slots, and tried one stick of RAM (with both) in all slots and I've reseated all cables and hardware to no avail. I have noticed though that when I apply a small amount of pressure to the bottom right corner of the MoBo, the computer boots but doesn't have any visual output. All fans are running; the GPU fans are running and the computer is evidently on.
Processor: i5 4440;
16GB Crucial DDR3 RAM;
60GB SSD; 500GB HDD;
Nividia GeForce 750TI;
Coolermaster Hyper 103 CPU Cooler;
AVP Hyperion Case;
Corsair CX550 PSU.
Any help would be greatly appreciated, I'm close to throwing the blasted thing out of the window.
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.”
― Charles Bukowski
Desktop | Intel Core i5 - 7600k | ASUS Strix B250F | MSI GeForce GTX 1080Ti x Gaming 11G | 256GB Samsung Evo | x2 WD Blue 1TB | Corsair Vengeance LPX (2x8GB)
Mini Desktop | Mac Mini | Core i7 2.3GHz | 8GB RAM | 1TB HDD x2
Laptop | MacBook Pro 13in w/Touch bar (2016) | Intel Core i7 | 8GB LPDDR3 | 1TB SSD
Laptop | Lenovo Thinkpad Edge | Intel Core i5 | 16GB DDR3 | 256GB SSD
Peripherals | Razer Chroma Orbweaver | Magic Mouse 2 | Corsair K70 RGB | Logitech G402 | Blue Snowball | Logitech G922 | Logitech Artemis Spectrum G933
Galaxy Tab S2 - used as a media streamer, more often abused by my 1 year old son.
https://linustechtips.com/topic/865554-newly-built-pc-boot-issues/
Can you test different hardware in another system? Although to me it sounds almost like it could be a motherboard or PSU problem.
I tested the PSU, RAM and GPU on another motherboard whilst I was waiting for the current motherboard to arrive. So that literally does leave the Mobo as the issue!
I'll rip everything back out again and check all the stand-offs.
― Charles Bukowski
I wouldn't think standoffs would be too big of a problem(unless you actually did forget some), you could also try running the computer outside of the case(the box makes a very handy antistatic testbench for this purpose), and if you still can't get it to work, RMA it.
Wish me luck, I'll keep you posted!
― Charles Bukowski
Good luck!
46 minutes ago, Crunchy Dragon said:
Good luck!
― Charles Bukowski
Alrightyo, I'll give it my best shot
― Charles Bukowski
and you were right! I had a rogue standoff that (I'm assuming) was short-circuting my motherboard. Thank you for your help!
― Charles Bukowski
