I just got into pc gaming this year and I have a really old computer and I want a upgrade. I have a budget of at maximum $800 but I would like it to be $750-$600. I have a idea for a build but if someone could help me edit my current build or help me it would be nice.
Oh and do I need a SSD (expensive little thing is what I’m thinking of)  and a larger hard drive (big cheaper silver storage come in TB and up) or what
do I need a extra attachment to connect to wifi if not using Ethernet
PC link https://pcpartpicker.com/list/PYnMBP
Or should I just buy a prebuilt
https://linustechtips.com/topic/864971-1st-gaming-pc-help/
You should probably go with the i5 8400 and wait for ATX B360 boards to come out.
Edited by LinusTechTipsFanFromDarlo
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/864971-1st-gaming-pc-help/#findComment-10745096
So I copied your current list, I do tend to agree that it might be worth waiting for the i5 8400 and the B360 boards to come out. Although if you are in a hurry the setup you have right now will work just fine. With the mobo you chose, you will need a wireless NIC. Wireless NICs are fairly cheap (about $35 for a good one). I did add an ssd to the build. One thing that you want to make sure you add into your budget is a windows 10 key. You can buy them legit for about $80-90 or you could buy it off a site that may be a bit sketch, and unethical. Attached is the revised version that I would personally recommend. One final thing I would make sure to do is with your RAM I would recommend doing a 1x8 not a 2x4, as going with a 1x8 allows for better future expandibility.
https://pcpartpicker.com/list/by4jf8
Edited by Just Wags
Screwed up wording
https://linustechtips.com/topic/864971-1st-gaming-pc-help/#findComment-10745260
that 4 core is going to start holding you back in the future, right now i would advise you to wait as in february new cpus will come out from amd, and around the same time the cheaper boards for coffelake will probably be released, so wait for that, try to get a 6 core cpu as now 4 cores is the low end, and the 6 core chips are not expensive, there is also the possibility to get a 1600 ryzen chip and a b350 board (as long as you dont plan to overclock too much) if you dont want to wait
https://linustechtips.com/topic/864971-1st-gaming-pc-help/#findComment-10745262
https://pcpartpicker.com/list/Z3k7f8
Check this out and edit it to your liking.
??? Wanna join ??? my free??gift card??? giveaway??? Click ⤵ the subrscribe button?? ,turn? the notifications on ??? and finally leave a nice comment ??down below⬇⬇ , now without further adue ??? lets get on?? with the video▶▶
https://linustechtips.com/topic/864971-1st-gaming-pc-help/#findComment-10745516
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($189.89 @ OutletPC)
Motherboard: Asus - PRIME B350-PLUS ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($79.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($78.99 @ SuperBiiz)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Amazon)
Video Card: Zotac - GeForce GTX 1060 6GB 6GB Mini Video Card  ($239.99 @ B&H)
Case: Cougar - MX330 ATX Mid Tower Case  ($24.99 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($19.99 @ Newegg)
Total: $753.82
Generated by PCPartPicker 2017-11-25 21:01 EST-0500
https://linustechtips.com/topic/864971-1st-gaming-pc-help/#findComment-10746820
  • 2 weeks later...
No point in getting the Z270 Mobo and the 7600k. There is no upgrade path. Wait for new boards to come out in Q1 2018 and get an i5 8400. No point in buying them now as the boards are expensive.
My personal PC:
CPU: Intel - Core i5 8600k  Cooler: CoolerMaster Hyper 212 Evo  Motherboard: Asus Prime Z370-P RAM: Corsair Vengeance LPX 2x8GB 3000MHz DDR4 Storage: San Disk SSD Plus 240 GB + WD Caviar Blue 1TB  Video Card: Gigabyte GTX 1070 Windforce OC 8GB Case: Phanteks Eclipse P400S Tempered Glass ATX  PSU: Corsair CX550M 80+ Bronze Certified Semi Modular PSU.
Peripherals:
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse Keyboard: Rii - RK100 Wired Standard Keyboard Monitor: Asus - VG248QE 24.0" 1920x1080 144Hz Monitor Headset: Logitech - G430 7.1 Channel Headset Speakers: Logitech - Z150 0W 2ch Speakers
Laptop:
Medion  E6239 MD99452
PCPartpicker Link:
https://uk.pcpartpicker.com/list/VVwvHN
https://linustechtips.com/topic/864971-1st-gaming-pc-help/#findComment-10793755
