Hey guys, my friend wants to upgrade his PC from an old build.
His specs are:
Intel core i5 4690
Intel stock cooler
Gigabyte - GA-Z97P-D3 ATX
8GB of DDR3 RAM (unknown model)
1TB Hard-drive (unknown model)
Radeon R9 270X
Unknown case
Unknown PSU (However i'm assuming it is the case PSU)
His budget is ~£1000, however i'm not sure if it would be best for his money to upgrade his current build and save some money, or create a completely new one from scratch.
He uses his PC mostly for gaming.
He currently has a 1080p/60hz display, but is looking to get a new monitor, however if he does, it comes out of his £1000 budget
He already has KB+M
He wants to run recent games as well as he can by spending his money as smartly as he can
Thanks for the help in advance :)
https://linustechtips.com/topic/864901-help-upgrading-a-friends-pc/
Just now, monkeyman7444 said:
UK
just confused pound symbol with euro, sorry
CPU: Ryzen 1700@3.9ghz; GPU: EVGA 560 Ti 1gb; RAM: 16gb 2x8 Corsair Vengeance LPX DDR4-3000; PCPP: https://pcpartpicker.com/list/b3xzzM
this is what i would reccomend
https://uk.pcpartpicker.com/list/B9CqD8
playing at 4k, the cpu will not be a bottleneck
upgrade with another 8gb of ram ASAP
Video Card: Palit - GeForce GTX 1070 Ti 8GB Dual Video Card  (£409.99 @ Overclockers.co.uk)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£48.15 @ Box Limited)
Monitor: AOC - AG241QG 23.8" 2560x1440 165Hz Monitor  (£419.99 @ Amazon UK)
Total: £878.13
Generated by PCPartPicker 2017-11-25 13:55 GMT+0000
and upgrade the CPU to this:
https://www.ebay.co.uk/itm/Intel-Core-i7-4770-3-40-GHz-Quad-Core-CPU-Processor/162771166086?epid=165742379&hash=item25e5eae386:g:AIQAAOSwZlZZ~1Vn 143.98 pounds
then, sell off the old parts and maybe get another 8gb of ddr3 and a 240gb ssd.
6 minutes ago, monkeyman7444 said:
Intel core i5 4690
Intel stock cooler
Radeon R9 270X
Unknown case
this is what i would do:
  • get i7 4770k (and maybe overclock it)
  • get better CPU cooler
  • throw in another 8gb of RAM if there are 2 slots left unused or replace the whole kit with a 16 gb kit
  • get SSD for boot drive (128gb or bigger)
  • get a better graphics card (1050ti or better)
  • replace the PSU if the one he has now is bad quality or just too weak for the
if he is happy with the case then there is no need to change that. otherwise a new case is also in order.
