Hi, i have a very wired problem and I can not find any fix on google so I hope someone can help me here.
I just bought a RX 580 and I crossfire it with my old RX 480.
Everything works fine, did an hour of stress test and it got great benchmark from Haven and 3DMARK Time spy.
However, when I start up Skyrim, and opened up the map, the screen goes black and the system restart and only the secondary GPU's fan is sniping, and the device manager shows that I only have one GPU installed in the system.  I managed to get my new RX580 working again by unplug and re-plugin the power connector.
I went back to skyrim again and disabled crossfire in the Skyrim game profile in AMD setting.  But still every time I open up the map in game my new GPU dies. This never happens when I have only the RX 480 in my computer.
I tried to play Mass Effect Andromeda, And with crossfire enabled I only get 20 fps. And 30 FPS when I disable crossfire.
I did the stress test on my new RX 580 and it works fine.  And in Afterburner, I set both CPU's clock speed to 1340, Memory clock to 2050, and power limit to maximum. And it works fine in Time spy and Haven.
My computer spec is:
cpu: i5 6500
Motherboard: Gigabyte Z170x-gaming 3
Ram: G.Skill 8gb DDR4 2400
GPU: RX 580/ RX 480 crossfire
PSU: Evga 750W
What caused this problem and how can I fix it?
https://linustechtips.com/topic/864757-crossfire-primary-gpu-die-in-game-problem/
Don't crossfire two different GPUS.
Do you remember the
21st night of September?
Love was changing the minds of pretenders
While chasing the clouds away
Our hearts were ringing
In the key that our souls were singing.
As we danced in the night,
Remember how the stars stole the night away
Remove the RX 480.
Do you remember the
Could be Skyrim not supporting Crossfire. Disable that and see if it works. If it doesnt then you can clean up the drivers with DDU, then reinstall it.
It's doable. They use the same cores and drivers do allow these two cards to go Crossfire
Desktop benching:
Thank you for informing me of my mistake I have looked it up and you are correct.
Do you remember the
Thanks for your reply.  Sadly Clean up video driver with DDU and disable crossfire didn't work.  But I did fix the FPS issue for Mass Effect by disable Crossfire.
I tried 7 games and the only game that has the GPU crush problem is Skyrim when opening Map.  (did not have this problem when I use only the 480.  I did more research and some people say it may be the PSU problem.  But the PSU calculator says I only need 670W even after overclocking.  I downclocked my 580 and it did not fix it either.
Any thought on what should I try next?
