Need Help ASAP - PC internet speed ultra low
Solved by BDev,
After almost giving up, i tried one last thing:
1- Run Cmd Prompt as Administrator.
2- Type: netsh int ip reset c:\resetlog.txt
3- Hit enter key.
4- Restart the PC.
Then:
1- Run Cmd Prompt as Administrator again.
2- Type: netsh winsock reset
3- Hit enter key.
4- Restart the PC.
And last but not least:
1- Go to Control Panel.
2- Internet Options
3- Go to the "Advanced" tab
4- Click "Restore advanced settings"
5- Click "Reset" right below it.
Doing all these steps in sequence fixed the problem. Now my speed is back at 1.8Mbps and no problem has occured so far.
