Hi,
My edge won't work. I start it. It's up for a few seconds. It shuts down. I use Chrome anyway. Might need it for some kind of support.
Tried Repair and reset under: Settings> Apps > Apps and Features > Microsoft Edge> Double Click> Advanced Features> Advaced Options>  first tried Repair, than tried Reset. Nothing there worked.
I have the Fall Creators Update installed. Any suggestions.
https://linustechtips.com/topic/863889-edge-wont-work/
7 minutes ago, Eric Kazer said:
Hi,
If you really must have Edge (I have yet to encounter a situation where it was needed), your best bet might be to use sfc /scannow from inside an admin command prompt or, failing that, a repair install of Windows.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/863889-edge-wont-work/#findComment-10736742
