Websites Not Loading Without https://www.
Hi peeps, recently my computer has been acting strangely whenever I have my vpn turned on. I use Astrill, and whenever it is on, websites will not load unless I type https://www. with the address bar. for example, google.com won't redirect to https://www.google.com automatically. It's probably something DNS related, but things work fine whenever the vpn is off (Aside from not being able to access google/youtube at all in China). I have noticed the same thing for both my school Macbook pro, and my home rig, yet non of my classmates experience the issue even when they are on the same networks as I am. What could be causing this? My default browser is google chrome, but the problem exists on all other browsers.
Thanks in advance
PC 0: Pinky 2.0
Ryzen 9 5950x — 64GB G.Skill Ripjaws 5 @3600Mhz CL14-13-13-28-288 — ROG Crosshair 8 Dark Hero — RX 6900 XT — Hardline Loop — Sabrent Rocket 4.0 2TB — Samsung PM961 1TB  WD Blue 4TB HDD — Corsair AX1500i — Thermaltake Core P5
PC 1: Pinky (Yes that is her name) Here's the build
Xeon E5-1680V3 — 64GB G.Skill Ripjaws 4 @2400Mhz — MSi X99A Godlike Gaming — GTX 980Ti SLI (2-WAY) — Hardline Loop — Samsung 950Pro 512GB — Seagate 2TB HDD — Corsair RM1000 — Thermaltake Core P5
PC 1.1: Pinky (Mom Edition) Here's the build
i7-5960X — 64GB G.Skill Ripjaws 4 @2400Mhz — MSi X99A Godlike Gaming — GTX 980Ti SLI (2-WAY) — Hardline Loop — Sabrent Rocket 3 1TB — Samsung Q 870 Evo 4TB — Corsair HX850i — InWin S-Frame #190
PC 2: Red Box/Scarlet Overkill (Dual Xeon)
Xeon E5-2687W x2 — 96GB Kingston DDR3 ECC REG @1333Mhz — EVGA Classified SR-X Dual CPU — GTX 1070 SLI (2-WAY) —Hardline Loop — Samsung 750 EVO 256GB — Seagate 2TB 2.5" HDD x3 — Self-Built Case
https://linustechtips.com/topic/863692-websites-not-loading-without-httpswww/
Thanks in advance
i think it's trying to find a local address.
Like how before (many years ago) you could search your local machine through a web browser. You had to specifically tell it that you wanted to connect to the web by typing www.
Check your VPN settings.
It's not a race to the bottom.
