Bent pin Ryzen
Go to solution Solved by Armakar,
If you put it back into place it's fine
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/863659-bent-pin-ryzen/#findComment-10734682
2 minutes ago, Clippy123 said:
Thanks! I am worrying for no reason
Even if it didn't work, loads of these pins are just placeholders. Some of them are just overvoltage protection, some of them don't do anything at all. Many people break the pins clean off and the CPU works fine.
Main Rig
CPU: Ryzen 2700X
https://linustechtips.com/topic/863659-bent-pin-ryzen/#findComment-10734694
