https://linustechtips.com/topic/863657-preparing-first-rig/
3 minutes ago, Edu_X007 said:
Hi guys.
https://ca.pcpartpicker.com/list/ss6szM
https://www.amazon.ca/gp/product/B071RM5NQD/ref=ox_sc_act_title_2?smid=AHWBCKVCY3PXA&psc=1
https://www.amazon.ca/gp/product/B002CQU14A/ref=ox_sc_act_title_1?smid=A27FJEHHGNYHHY&psc=1
This is my current build, with the keyboard and the thermal paste.
I have been debating about the processor, PSU and ram.
Should I go with an i5-7600K, this one (whenever it is here again, or would a i5-8400 be good for it?
Also, is a DDR4-3000 is okay, or should I go with lower speed?
550W - 650W is more than enough psu for the build.
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10734687
Thanks! I updated the list on the first post. Now, I've been told that the motherboard I have now is not good for the i5-7600K. Any recommendations on that? Also, how much performance would I be able to increase with the fan I included?
https://ca.pcpartpicker.com/product/CrDzK8/corsair-cpu-cooler-cw9060025ww
I was recommended this one, but it is quite pricey, so I was wondering if I would need that much increase.
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10736638
If you plan to overclock the i5-7600K you will need to use a z270 motherboard. But I would suggest going with the latest generation hardware.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($239.75 @ Vuugo)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($46.75 @ Amazon Canada)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  ($154.99 @ Newegg Canada)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($199.99 @ Newegg Canada)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($121.95 @ shopRBC)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.99 @ Newegg Canada)
Video Card: EVGA - GeForce GTX 1070 8GB SC GAMING ACX 3.0 Black Edition Video Card  ($544.99 @ Amazon Canada)
Case: Fractal Design - Focus G (White) ATX Mid Tower Case  ($54.99 @ Newegg Canada)
Power Supply: EVGA - SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($109.99 @ Amazon Canada)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($258.19 @ Amazon Canada)
Keyboard: DREVO 84 Keys Gramr Wired Gaming Mechanical Keyboard with Backlit Edition Brown Switch (White)  ($64.99 @ Amazon Canada)
Mouse: Redragon - Centrophorus M601 Wired Optical Mouse  ($17.99 @ Amazon Canada)
Total: $1867.56
Generated by PCPartPicker 2017-11-23 11:29 EST-0500
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10736701
Total: $1867.56
Just to understand, why would you recommend the i5-8400 over the 7600K?
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10736730
  1. The i5-8400 has six cores with the same or better performance than a stock i5-7600K in gaming. https://www.techspot.com/review/1502-intel-core-i5-8400/.
  2. I5-8400 is latest cpu generation.
  3. Better than the i5-7600K in highly multithreaded environments.
The i5-7600K can be overclocked if one is willing to invest in a decent cpu cooler. An overclocked cpu would perform better in some games than the i5-8400.
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10736765
So if I went with my current cooler, you would say the 8400 is better? And what if I went with the other I linked before?
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10736855
The Hyper 212 Evo should allow some overclocking of an i5-7600K. But overall, I still think the i5-8400 is overall a better choice. The H100i v2 is a high performance cpu cooler. It should allow for an excellent overclock of an i5-7600K. The i5-8400 would still be better at some things, but the i5-7600K would do noticeably better in many games and other lightly threaded applications.
https://linustechtips.com/topic/863657-preparing-first-rig/#findComment-10738173
