15 minutes ago, Legogamer said:
Im trying to make a build that can do 60fps 1080p on modern games.
I have a build here https://ca.pcpartpicker.com/user/Legogamer/saved/LBrqkL
I would like to keep the price around the same with a absolute max of $650cad. Any changes that would benefit me?
Damn your pricing sucks in canada, Ryzen is expensive, RX 570s are still really expensive. Well if you don't want to wait for Raven Ridge APUs whenever those come out that's probably the best you're getting
Consider doing a Hybrid Drive instead of just an SSD for now if you want 2TBs of storage
Maybe a bit nicer case
definitely change out the PSU for this one
Also look for a 1050ti with a 6 pin if possible.
PCPartPicker part list: https://ca.pcpartpicker.com/list/rfYTsJ
Price breakdown by merchant: https://ca.pcpartpicker.com/list/rfYTsJ/by_merchant/
Storage: Seagate - FireCuda 2TB 3.5" 7200RPM Hybrid Internal Hard Drive  ($124.92 @ Amazon Canada)
Case: Deepcool - TESSERACT WH ATX Mid Tower Case  ($34.99 @ Newegg Canada)
Power Supply: SeaSonic - S12II 520W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Newegg Canada)
Total: $219.90
Generated by PCPartPicker 2017-11-22 21:24 EST-0500
https://linustechtips.com/topic/863645-budget-build-help/#findComment-10734602
