I don't know much about Java, but PLEASE:
Next time you post source code, put it in the code-Brackets (<>). This will make life easier for you and for the people who wnat to help you :)
public class Utility{    public static void main (String[] args)    {        double[] array1 = {1,22,333,4444,55555};                for( double value : array1 )            System.out.printf("     %f", value);                if (ascendingOrder(array1))        System.out.println("\nTrue");        else            System.out.println("\nFalse");                int [] array3 = {0,1,3,2,3,0,3,1};        int x = 3;                removeTwo(x,array3);        for (int value : array3)            System.out.printf("%d",value);    }            public static boolean ascendingOrder(double[]array2){   for(int i=0; i<array2.length-1;i++)    {        if(array2[i]>array2[i+1])            return false;    }    return true; }        public static int[] removeTwo (int x, int[] array3)    {        int counter = 0;        boolean[] barray = new boolean [array3.length];        for (int k=0; k<array3.length; k++)        {            barray[k] = (x == array3[k]);            counter++;        }             int[] array4 = new int [array3.length - counter];         int num = 0;         for (int j=0; j<array3.length; j++)    {         if(barray[j] == false)        {            array4[num] = array3[j];            num++;        }             }         return array4;    }     }
MB: MSI Z77A-GD55 | CPU: Intel i5-2500k @ 4.5 GHz | RAM: 8GB Kingston DDR3 @1333MHz | GPU: Asus GTX 770 DirectCU II
Monitor: 22" Samsung SyncMaster B2230H @60Hz | Audio: Creative Aurvana Live! | PSU: SuperFlower 80+ Gold 550 Watt
OS: ArchLinux + KDE / Windows 8 Pro 64bit | Smartphone: Nexus 4 16GB - CM11
https://linustechtips.com/topic/86360-java-arrays-help/#findComment-1172663
Not many people are good at Code here on these forums. If you have questions about code, try and find a code forum :D (Or reddit :P)
pfff ....
public class Utility{    public static void main (String[] args)    {        int [] array3 = {0,1,3,2,3,0,3,1};        int x = 3;          removeTwo(x,array3);        public static int[] removeTwo (int x, int[] array3)    {        int counter = 0;        boolean[] barray = new boolean [array3.length];        for (int k=0; k<array3.length; k++)        {            barray[k] = (x == array3[k]);            counter++;        }                // HERE!!!        // array3.lenght == 8        // counter == 8         int[] array4 = new int [array3.length - counter];        // THE LENGTH OF THE ARRAY 4 IS ZERO !!!!         int num = 0;         for (int j=0; j<array3.length; j++)    {         if(barray[j] == false)        {            array4[num] = array3[j];            num++;        }             }         return array4;    }     }
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
https://linustechtips.com/topic/86360-java-arrays-help/#findComment-1172664
